Old 05-04-2020, 08:13 PM
hi-tech cobra's Avatar
hi-tech cobra hi-tech cobra is offline
Cobra Make, Engine: Hi-Tech
Originally Posted by MOTORHEAD View Post
If I was going the same route as you, I would pull the heads and check the cyl walls for damage and wear (ring ridge at top) NO wait !! before pulling the heads, put starter and flywheel back on it and the valve train parts and cam gear and chain and do a cold cranking compression check on it. if they check ok, then do your mods, heads, cam and intake should give you plenty power, and all new stuff will fit the new block.
MOTORHEAD, a few of the bolts are missing on one of the heads. I'll hunt for them and do the compression test. Should the engine be cleaned before rotating it?
