Old 05-05-2020, 03:53 AM
1795's Avatar
1795 1795 is offline
If you move the transmission tail a little towards the drivers side it will free the driver's side header up a little, but at the same time it will pull the passenger side header closer to the frame. The transmission yoke seems fairly well lined up with the yoke on the differential You want the two yokes in a parallel plane and the tail of the transmission slightly higher than the diff. It looks pretty good right now Don't start changing things as that will compound other problems. As previously said, if you change the alignment of the transmission tail, then it might move the headers to the post that the side pipes do not line up correctly with the cutouts.
