Old 05-05-2020, 06:05 AM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
You mentioned the crud in te valley, you should pull the pan and see whats in there. You must put the valve train pieces back on, and if your lifters are hydraulic, you'll need to build up some oil pressure to pump them up. You must run the oil pump with a shaft thru the distributor hole with a drill..
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
