Old 05-05-2020, 08:42 AM
AC Ventura's Avatar
AC Ventura AC Ventura is offline
Cobra Make, Engine: AC Cars Limited, 302 EFI
Default Taurus fan
My car is an AC Mk IV and I used the standard 302 radiator for the 427FE swap. Its a similar rad to the Fluidyne, but has a smaller 3", not 3.5" core. I modified the shroud, by making fiberglass mouldings that enable it to be attached to the radiator with radiator cable ties. Works perfect if you use the Volvo controller and BMW radiator, M22 thread, dual temp switch. My FE can idle in traffic for an hour, in summer traffic with the fan alternating between high and low speed. I also fitted two warning lamps to the dash, so I can see which speed is coming on.
