Old 05-08-2020, 02:10 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by FredG View Post
Talk about complicating something.....When I purchased the car the previous owner told me the 427r was a bit finicky in that it didn't like lower RPM's specifically under 2k but past that the power comes on very quickly. I think it took all of about 15 min to adjust my driving habits and shift points. Problem solved.....nothing else need.
Fred
Yes. The only issue I have had regarding a cam, is with an all aluminum engine, and solid roller, that do to thermal expansion, I had to try to adjust the lash so tight when cold, I had some issues starting and running the engine until it warmed up, and then was fine after that, although I had to run the lash a little looser than recommended.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
