Old 05-12-2020, 09:30 AM
strictlypersonl strictlypersonl is offline
FWIW, that's Acton Cobra, not Action Cobra.
If you install it on an Arntz, make sure that the path is perpendicular to the axis of the lower control arm pivots.
https://actoncobra.com/index.php?mai...roducts_id=430
I also contemplated using a torque damper instead of the rigid design. It only requires one frame attachment, although you still must add a bracket to the hub carrier.
https://www.summitracing.com/parts/g...RoCgngQAvD_BwE
