Old 05-14-2020, 01:03 PM
olddog olddog is offline
Originally Posted by xb-60 View Post
No, the Windsors available in Australia from the mid ‘60s through to around 2002 (minus a few years in there somewhere) weren't derived from the Clevelands. Cleveland 351s and a small number of 302C engines were also available, but only from 1970 to 1982.
There were two Windsor engines available for the last few years up to the cut-off in November 2002 ….a 5.0 litre and also a 5.6 litre (a 5.0 with a 3.4 inch stroke).
Some of these engines were stripped, blueprinted and rebuilt by Tickford (then a subsidiary of Ford) and fitted to Falcons and Fairlanes, so technically, even though they were made in the US late last century, they were still being fitted 'new" to Fords up until late 2002. The later 5.0 engines were rated at 220kw (close to 300hp) and the 5.6 (342ci) somewhat more.
Initially, 5.0 litre 220kW engines had aluminium alloy heads, but post May 2001, Tickford changed to CI heads (GT40P) with Yella Terra rockers. These have a larger ratio (input to output) of 1.72:1 Compression ratio was raised to 9.4
Why fit a LS engine in a Cobra? I’m the wrong person to answer that one. The Tickford engines satisfy the required emissions requirements, as do the GM engines.
Here’s the “T” label on my engine….
Thank you for the info. Since I have never stepped foot in your great Country, I'm a bit ignorant of the history.
