Old 05-18-2020, 03:59 PM
xb-60's Avatar
xb-60 xb-60 is offline
Originally Posted by rsk289 View Post
They are simply a push fit. The four lugs should grip tight enough in the hole to retain it OK, so trial fitting when you make (or trim) the hole is important....
Roger, due to luck rather than intention, the fit of the ammeter is a tight push fit. I think I'll also use Tim's suggestion and also use a hose clamp for extra security.
Interestingly, I have an almost identical looking, but 50A meter, and it has a central threaded stud for the more conventional securing clamp
Glen
