Old 05-22-2020, 06:06 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by saki302 View Post
How about inside the side vents? You'll see the lights when they turn on.
Not sure if it'll pass inspection, but technically it's there..
Don't think so.
From
Annex 1
CATEGORIES OF DIRECTION INDICATORS:
MINIMUM ANGLES REQUIRED FOR LIGHT DISTRIBUTION IN SPACE OF THESE CATEGORIES OF DIRECTION INDICATORS 1/
In all cases, the minimum vertical angles of light distribution in space of direction indicators are 15 degrees above and 15 degrees below the horizontal, in the case of direction indicators of category 6 however they are 30 degrees above and 5 degrees below the horizontal.
Minimum horizontal angles of light distribution in space:
Categories 1, 1 a and 1 b: direction indicators for the front of the vehicle:
Category 1: for use at a distance not less than 40 mm from the headlamp;
Category 1a: for use at a distance greater than 20 mm but less than 40 mm from the headlamp;
Cateqory 1b: for use at a distance less than 20 mm from the headlamp.
Category 2a: Direction indicators with one level of intensity for the rear of the vehicle.
Category 2b: Direction indicators with two levels of intensity for the rear of the vehicle.
Category 3: Front-side direction indicators for use on a vehicle equipped with this category of direction indicator only.
Category 4: Front-side direction indicators for use on a vehicle also equipped with category 2a or 2b direction indicators.
Cateaories 5 and 6: Supplementary side direction indicators for use on a vehicle also equipped with categories 1, 1a or 1 b and 2a or 2b direction indicators.
Gary
