Thread: Tires
Old 05-27-2020, 02:04 PM
MKS427's Avatar
MKS427 MKS427 is offline
Cobra Make, Engine: FFR MkIV 427
Originally Posted by hauss View Post
I am running nitto nt 05s on my car and thinking of changing to a different tire. I do not like the way the front tires, cause the car to jump around.What would be a good performance tire with good manners that you could recommend ? 245 17 front and 315 17 rear car is a 2013 backdraft around 600 hp. Thank you for your thoughts.
The jumping around is tramlining. It occurs more frequently with wider tires and more aggressive alignments. You could put more caster in the alignment to reduce.
NT01s are what I run, but they are no good wet. I have no intention of driving in the rain. FFR recommends Toyo Proxies R888. They have a good rain rating, but I have never tried them. They are available in the sizes you are looking for. Toyo and Nitto are sister companies, from what I've been told.
Good luck, be safe
Mark
PS: Try 22 psi to start with that size tire on the Cobra.
