Old 06-01-2020, 12:42 PM
BAsque1's Avatar
BAsque1 BAsque1 is offline
Ron: Update tested both fuse holders for ohms, no reading, tested the fuse holders for amperage, car was off fans off no reading. Turned the car on repeated above same results. Another friend retired automotive teacher feels that is either heat or slow high amperage. No breaks on any of the lines, checked all connections ok, this is a mystery. Fans run fine at the right temp what else could cause this???? See the pictures of the two fuses burnt.
Basque1
