Old 06-02-2020, 05:28 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Are these mini fuses?
I would be using a maxi fuses, and measuring the startup current.
ALL electric motors draw more current at startup, especially in a switched on/off scenario.
Resistance anywhere else in a motor circuit will LOWER overall current, and fan speed.
That's how we alter interior fan speed.
You can locate poor connections as a voltage drop test across each connection, and can be felt as heat in extreme cases.
Gary
