Old 06-02-2020, 06:03 PM
patrickt patrickt is offline
Originally Posted by Gaz64 View Post
Are these mini fuses?
I would be using a maxi fuses, and measuring the startup current.
ALL electric motors draw more current at startup, especially in a switched on/off scenario.
Resistance anywhere else in a motor circuit will LOWER overall current, and fan speed.
That's how we alter interior fan speed.
You can locate poor connections as a voltage drop test across each connection, and can be felt as heat in extreme cases.
On your DC motor, as the voltage drops (because of a bad connection) the motor current will increase (but the speed and torque will decrease). Now, I know you're going to look that up, and when you do, you have to come back and write "well, ok Pat you were right."
