Old 06-03-2020, 12:53 PM
Quentin Z's Avatar
Quentin Z Quentin Z is offline
Cobra Make, Engine: Backdraft #272, 351W
Originally Posted by FredG View Post
I added camber plates and a little stiffer spring to the front as well as upgraded all 4 shocks. I upgraded the manual steering as well.
Fred,
Funny, I just tried to install camber plates last night. Turns out that I need camber nuts (threaded sleeve/nut) because the top part of the stock KYB 361005 shock inserts are too short. What upgrade front shocks and springs are you using? Also, did you have to trim the camber plates to fit in the tower, and what manual rack are you using?
