Old 06-03-2020, 04:24 PM
FredG's Avatar
FredG FredG is offline
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Camber plates
Originally Posted by Quentin Z View Post
Fred,
Funny, I just tried to install camber plates last night. Turns out that I need camber nuts (threaded sleeve/nut) because the top part of the stock KYB 361005 shock inserts are too short. What upgrade front shocks and springs are you using? Also, did you have to trim the camber plates to fit in the tower, and what manual rack are you using?
You sound like you are going through exactly what I went through. I added an Eibach spring kit to the front from Iconic. The original shocks were Gabriels and they were mush. I replaced them with the KYB's. Same ones you have and I also thought the shock inserts were short. I have the stock rack. Here's the problem, if you got the Camber kit from Iconic, they probably shipped it to you assembled but it's not assembled in the manner it goes on the car. It's all wrong. It drove me crazy til myself and another fellow who posts here figured it out. I tried putting it in every which way and even considered modifying them. Finally figured it out by taking them apart. Take a look at my gallery pictures as there are pictures on there as to how they go together. Good luck.
Fred
