Old 06-03-2020, 06:44 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
BAsque1 you said "fans" which I assume is two. Have you checked the amp load of the fans?
Is there a label on the fan or model number where you can see what the fans amp load is suppose to be?
The best way to check is with an amp meter. I bought a industrial 50 amp DC meter and wired it so I can pull a fuse then plug in the meter to read the amp load. Some Multi meter will check a 30 amp load but mine with not. That's way I bought one.
Check a fan last fall that was labeled at 7 amps but when we check it over 15.
Oh, another thing to check is wire size.
