Old 06-07-2020, 08:14 AM
Mattsvtcobra Mattsvtcobra is offline
Cobra Make, Engine: Backdraft #360
Default Radiator setup question - leak help
I found a leak in the thermostat housing, but I also found a leak on the upper drivers side of the radiator plastic housing. There is a small hose from the chrome fill tank that goes over the big pipe (that routes to the thermostat housing) and they go to the upper corner of the radiator. I will attach a picture, but I want to know if anyone has a shot of how that little tube it attached to the radiator. It is a super tight spot to get to... so any suggestions would be awesome. Based on the big tube being wet all the way around, it seems like it would be coming from above it.
Edit: the image is rotated, but this is the upper left corer area.
