Old 06-07-2020, 09:39 AM
ERA 626's Avatar
ERA 626 ERA 626 is offline
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Originally Posted by Tjd View Post
Disconnect lower ujoint from the intermediate shaft that on the steering rack Pinion and see if it’s in the steering column or in the rack that’s causing the bind there should be next to zero restriction when you turn the steering column when it’s not connected to the rack give it a try and good luck
Tom
Thanks Tom, I have had the steering column apart several times because of the removal of my dashboard related to the drama I had with my gauges thanks to nissonger (jerk) another topic all together.
Its not in the steering column. I cant seem to separate
the tie rod from the spindle with out tearing up the rubber boot. is there a way to lubricate the steering rack?
