Old 06-07-2020, 04:43 PM
tortuga tortuga is offline
Default Second Round Valve Stem Seals...
So in my seemingly never ending quest to reduce oil consumption, with the carb off i was endo scoping my intake and it sure looked like there was oil coming down the valves...I had done all the seals before using the compressed air in the cylinders method...
On reading some more about how to replace the seals i came across lots of chatter about using a drinking straw arrangement over the valve stem so that the seals don't get torn as they pass the sharp reliefs where the keepers plug in. I didn't do that.
So having another set of seals, ( i double ordered and just kept the batch).
I pulled them off and replaced them one by one, this time using a tricky straw arrangement to slip them on. ALL of the old seals were wallowed out. Is just jamming the seals down over the stems without a condom a mortal sin?
We'll see...
Im getting pretty good at it at this point.
Steve H
SPF 1764
Superformance 1764
Built 427W
Aiken SC USA
