  #23 (permalink)
Old 06-09-2020, 03:23 AM
BAsque1's Avatar
BAsque1 BAsque1 is offline
UPDATE On fans issue:
Yesterday I tested the fans isolated from everything, placed the ammeter on line and each fan by itself, the initial amperage was 45-50 amps to kick on at 205o. Checked all connections ground etc and all are fine. Relays are working fine, I replaced the mini fuses for 30 amp circuit breakers. I changed the radiator cap for a brand new one 13lbs as required in the event that the old cap was not venting properly and added Water wetter to the coolant. At this point I am watching and see if it happens again.
Basque1
