Old 06-10-2020, 04:19 AM
1795's Avatar
1795 1795 is offline
Micheal,
The cross bar that your shoulder straps are attached to should be located such that the point is between either exactly at your shoulder height or 10 degrees lower than your shoulders. It cannot be above your shoulders or else you will be at risk of sliding out if the vehicle gets upside down. At neutral to 10 degrees below you are at low risk for compression of the spine. This is from the SCCA rules.
Jim
