Old 06-10-2020, 10:19 AM
Hall1836 Hall1836 is offline
Cobra Make, Engine: Superformance 351/427 stroker
Default update
Update on shimmy. Had the tires rebalanced on a a Hunter machine (not road force) added additional weights and not much of a difference. Then had the tires checked and balanced on the Hunter road force by a shop that has been around for years, noticeable difference but still had a shimmy over 64 MPH. Called the shop and they stated it had it had to be something other then the tires and wheels because they balanced out and wheels were fine. I was starting to believe it was the tires and wheels because each time they were done there was some difference. Went to an other recommended shop and had the tires done on the Hunter Elite Road Force, huge improvement, not a hundred percent but the best I've had. Very small vibration above 60 plus miles and will live with it. May still consider the ball joints. Thanks to Jim jhv48
