Old 06-12-2020, 03:32 AM
xb-60's Avatar
xb-60 xb-60 is offline
Originally Posted by Gaz64 View Post
A leveller, a 2nd pair of hands, and rear end of car up high on stands.
Gary
Sounds like a plan Gary.
The last engine out/in, as I said, was 'some years ago'. Had to replace the clutch plate on a car that I'd prefer not to mention (a less than illustrious GM product), so needed to remove the engine and gearbox because of lack of room between engine and firewall, and when I started the engine after replacing the clutch plate, and depressed the clutch, I knew immediately that I had the clutch plate in the wrong way around. Hence, remove-and refit engine and gearbox twice in one day. You learn by your mistakes, yes?
Glen
