Old 06-12-2020, 09:41 PM
xb-60's Avatar
xb-60 xb-60 is offline
...If you put them in apart you can get some 5" long bolts that thread into the bell housing, cut the heads off and thread the into the bell housing (once the engine is secure on the mounts) and use them as guides to slides the top loader on and slide it forward....
Jim,
I'm thinking that I need to have the engine/scattershield/Toploader assembled already. Apparently there is not enough tunnel room for a clutch fork, so will need to be using a HTOB. Otherwise the long studs is a good idea.
Glen
