Old 06-12-2020, 11:26 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by xb-60 View Post
Sounds like a plan Gary.
The last engine out/in, as I said, was 'some years ago'. Had to replace the clutch plate on a car that I'd prefer not to mention (a less than illustrious GM product), so needed to remove the engine and gearbox because of lack of room between engine and firewall, and when I started the engine after replacing the clutch plate, and depressed the clutch, I knew immediately that I had the clutch plate in the wrong way around. Hence, remove-and refit engine and gearbox twice in one day. You learn by your mistakes, yes?
Glen
Yes, I have helped a friend of mine who did the same thing. He wasn't happy either.
I have also witnessed a motor "drop" into an engine bay, when a cocky 2nd year said "I'll do the valve thing".
Amazingly it fell to the mounts, lined up etc. It came out for inspection, and then went in again with some better experience. Gary
Gary
