Thread: Name this tick!
Old 06-13-2020, 07:24 PM
patrickt patrickt is offline
If the car runs well, the pipes heat up evenly, and you even watch the valve train with the covers off and every valve goes up and down cleanly, then I would try and locate the tick using a mechanic's stethoscope. An engine tick coming out of a Surface is a little tricky to identify. The fact that your engine runs well is a good sign. A stethoscope will help you spot the location of the noise, if it's mechanical (it could even be something like a mechanical fuel pump misbehaving).
