  #21 (permalink)
Old 06-13-2020, 07:31 PM
xb-60's Avatar
xb-60 xb-60 is offline
I did the install myself on my ERA because I'm a bit anal and consider all my car buddies a bit ham fisted. Because of that I mounted the clutch/flywheel and dropped the engine straight in by itself. Then I bolted on the bell housing and installed the transmission from inside the interior. The only issue I had with this is that the Toploader is a heavy transmission and mounts considerably up and under the instrument panel/cowl. I've learned to work around this by cutting 4 lengths (roughly 10" long) of all thread to thread into the trans to bellhousing bolt holes. Then I slide the transmission on plywood covering the floor over to the center, stand straddling it and heft it up on to the 4 dowels. From that point on, if you got the disc aligned accurately ( I would test fit to engine while on the ground or hoist first), my transmission slides into place like closing the bolt on a bolt action rifle.
But if you have a helper you can install it all assembled with a go-slow approach.
Some good advice there Dan. We are on the same page with a number of things there.
I do recall from your build thread the idea of the long studs for aligning the gearbox, but I have no removable sheet metal to give me access from above; my tunnel has limited clearance to the Toploader, so engine and gearbox will have to go in as one unit.
The "go-slow approach" is the way to go.
Glen
