Old 06-16-2020, 10:03 PM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
I would agree with cycleguy55, install a aircraft type breaker switch (toggle type). I was having a similar problem with a clients car. At start up or if he blipped the throttle the current surge would blow the cooling fan fuse, not good if you are stuck in traffic and you have to get to the side of the road to change the fuse. We installed the aircraft type circuit breaker and it’s worked out well. If the breaker blows all you have to do is cycle the toggle switch to restart the fan, You don’t have to pull off the road to change a fuse either.
