Old 06-20-2020, 06:28 AM
bobcowan's Avatar
bobcowan bobcowan is offline
My first Cobra was a CR with a small block and solid axle rear. The ride was pretty harsh. Changing shocks was a good first step. You'll have to remove the springs to see what you have. It's usually engraved on the top/bottom of the spring. If you decide to change them, use Eibachs. Makes a huge difference.
Tire pressure should be around 22psi
Disconnect one end of the sway bar and drive it around a little. I doubt that it will make much of a difference.
Also, check for binding in the suspension. Poly bushings are famous for binding up over time. That makes a Really harsh ride.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
