Old 06-20-2020, 08:05 AM
Alfa02's Avatar
Alfa02 Alfa02 is offline
Gold Star Contributor
I too brought a unfinished CR kit (Poly bushing), years ago, and found the same thing. As I discovered at the factory as a roller(Less Motor & trans) they tighten everything to specs. on the A-arms, etc. When you install the Motor, etc the bushing will bind, just put it up a hoist, loosen all front sup. bolts and let everything "Relax" then retighten all bolts to spec. Hope this helps Cheers TommyRot.
