Thread: Rear end
Old 06-22-2020, 11:20 PM
eschaider's Avatar
Originally Posted by Bulldog View Post
Edthanks for reply, opinion depth I can't ember shim thickness but backlash was about 8thousand.just seems like flange has some play in it it did t have when I assembled it.everything sounds ok maybe am just over thinking it!
Pinion depth is not the thickness of the shim it is the distance from the center of the carrier bearings to the face of the large bearing seat on the backside of the pinion. It is apparent that you did not set this dimension when you assembled the ring and pinion to the carrier. This needs to be done.
Once you have pinion depth correct then you want to assemble the ring gear to the carrier to minimize runout. Both the ring gear and the carrier will have some amount of runout. What you want to do is measure the runout and then clock the two during assembly to minimize the assembled run out. That will allow you to run less back lash without the ring and pinion binding up.
Rotate the pinion multiple times to be sure it has no crabs anywhere throughout a complete rotation of the ring gear. If you have a 3.08 ratio it will take 3.08 turns of the pinion. If you have a 3.55 ratio it will take 3.55 turns of the pinion. Always round up so 3.08 will become 4 turns and 3.55 will also become 4 turns.
If you have properly minimized the runout you can easily run with a 0.005" backlash. If you have very good control of the runout you can go as low as 0.003" to 0.004" but you will need an oil cooler because the tighter clearance will add heat to the operating assembly, especially on the highway. Do not go below 0.005" back lash without an oil cooler.
If this type of setup is a bridge too far, then you need to take your rear end to a shop to have the work done for you.
Ed
