Old 06-28-2020, 11:12 AM
olddog olddog is offline
Is that a fuel line and filter out the back under the bumper?
I agree you need to say that the engine is a 385 series, if built on a 460 block. It is possible to build a FE that big with a few aftermarket block, but the heads did not appear to be FE, but I couldn't see enough to be certain.
I also agree that much compression requiring race fuel will shorten your potential buyers list. If I were thinking about buying it, I would be factoring in the cost to rebuild the engine and drop the compression ratio, so I could run pump gasoline.
