Old 07-01-2020, 01:10 PM
KirkV KirkV is offline
Cobra Make, Engine: Superformance #678
Sounds like you may have a leaking o-ring in your throw out assembly. You can usually see a fill to line about 3/4 ways up the reservoir to refill the bottle to.
At some point you need to repair the leak yourself or have it serviced as it will only get worse and there’s nothing like being somewhere stuck in one gear because the clutch pedal has dropped to the floor.
Hope this helps.
