Thread: Oil cooler
Old 07-10-2020, 09:02 AM
Chicagowil's Avatar
Chicagowil Chicagowil is offline
Originally Posted by DucatiThunder View Post
Those early trombone coolers were a joke. When they switched to the later carrera cooler in mid to late 80s they worked extremely well and needed a thermostat. Eventually the displacement reached the need for 2 carrera style coolers in the fenders in the 964/993. I have seen alot of oil bypass mods and thermostat mods allowing full flow but usually extra precautions were taken on oil selection.
You are right. Most of the cooling was the heat exchange of the oil was in the lines from back to front and return again. As the motors got larger and the turbos appeared, heat exchangers for the oil cooling had to be added. The best of the lot was the Ruff front chin oil rad. But it still had a thermostat on it.
Thom
