Old 07-14-2020, 04:24 PM
cycleguy55's Avatar
Originally Posted by Gbalko View Post
I have another issue. The top part of the body of the shock is hitting the hole under the mounting tower. should I enlarge the hole, lower the tower, get narrower shocks?
I'd enlarge the hole. Remove the spring and shock, then remove some material. Re-install the shock and cycle the suspension throughout its entire range of motion using a floor jack or a bottle jack, even beyond what you think you will actually use. Check clearance and keep removing material until you have about 1/8" clearance through entire range of motion. Once there, re-install spring and shock, set ride height and check again.
Brian
