Old 07-17-2020, 03:45 AM
S1965C S1965C is offline
Moriarty, after you follow what Gary has suggested, you may also want to install a lower power valve. If you’re pulling only ~6 inches of vacuum at idle and currently have a 6.5 valve on the primary side, it’s already bleeding and you probably have a very rich idle condition as a result. But adjust the throttle blades first to determine what your corrected idle vacuum is before throwing parts at the carb.
