  #23 (permalink)
Old 07-17-2020, 09:27 PM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
If your master is still in good shape just have someone press the clutch petal as you bleed the fluid from the slave. It should not take very long to bleed the system this way. check for proper alignment also do not let the master empty while bleeding . If you still wish to use the vacuum you can purchase one at orielys for 40$ not needed in my humble opinion.
