Thread: Csx 6027
  #26 (permalink)
Old 07-18-2020, 07:15 PM
1795's Avatar
1795 1795 is offline
Steve,
Congratulations and enjoy. Unless they said that all of the fluids have been changed, I would suggest changing the oil and checking the radiator fluid. Not enough miles to make much of a difference on the transmission or differential. Although, it probably would not hurt to change them as well, as oil does tend to deteriorate over time. Take a close look at the age of the tires, if original replace them as they will have deteriorated over time. My only other suggestions would be to keep the revs at 4,000 or below for the first few hundred miles as you break things in, and make the first drive a long enough one to bring the engine up to temp and burn off any condensation that has collected. It is possible that the engine has not been brought up to temp in some time, if ever if it was only moved around to change storage spots.
Good luck, and yes please post video.
Jim
