I have always loved solid lifter engines, and I've been setting valves for almost 50 years. I have
never set them hot with the engine running. When I was working at service stations in high school and college, there was always some old flea bag mechanic, who was probably out on parole, who would say
"in my day, we always set 'em hot with the engine runnin'." But I never saw anyone set them with the engine running, just say they used to do it that way.
Now, here is one lesson that I have learned with my FE engine regarding solid lifters. I have listened to and studied my iron block/aluminum headed mill for almost 15 years now and the fact that it has a solid, flat tappet cam and the clatter that it makes, or doesn't make, depending on the time and temperature after start up. I gap my valves at .018" COLD and I have aluminum roller rockers. The cam maker calls for a lash of .025" HOT. The classic answer to the difference between cold and hot lash on an iron block/aluminum headed engine is .007", give or take. When I first start my engine up COLD, there is virtually
no valve clatter at all. When I then take her out and she begins to warm up, as measured by the coolant temperature, the valve clatter will be at its loudest and sharpest when the coolant becomes hot but the
oil is not. That is when the aluminum heads and rockers have now had a chance to heat up, and expand, but the iron block has not. As the
oil temperature reaches the same temperature as the coolant, the valve clatter reduces down to a "normal" level of clatter. This is because the temperature of the iron, and the expansion of the block, has now had a chance to catch up with the temperature, and the expansion, of the heads. A few years ago we had a thread over on the FE forum about the difference between cold and hot lash on iron block/aluminum headed FEs with SFT cams. A couple of guys took it on themselves to go out to the garage, check their lash while cold, then they drove the car until the coolant showed it had warmed up, pulled back in the garage, checked their lash again, and proclaimed the difference to be .011" to .013" difference! That was quite a change from the standard answer. Of course they did not run their engines until the block was at the same temperature as the heads, just until the coolant got hot. When I run my engine, the lash starts out as .018" and the valve train is quiet as a mouse, the lash then grows to .030" or more for a short while (when the heads have expanded but the block has not), and the valve train has a really nice, pronounced clatter to it. Then the lash shrinks down to .024" or so and has a "normal" clatter to it. It actually took me quite a while to figure this out.
