Old 06-13-2002, 07:40 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
They'll be really hard to push. That is a big bore for dual master cylinder brake setup. The mechanical advantage of having a long skinny master cyl piston pushing a short fat caliper piston lets you translate a long foot travel distance with little force into a short travel brake piston distance with lots of pressure. Then again, depending on the piston size of the caliper and brake pedal arm ratio.......
