  #25 (permalink)
Old 07-24-2020, 08:50 PM
FredG's Avatar
FredG FredG is offline
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Ending
You should have never started. Remember what I said about George Carlin.
Originally Posted by Gaz64 View Post
So, as you can see Fred, others also with lots experience, have chimed in with their own life long experience of setting valve lash on a solid cam V8 similar, as in your example.
You cannot possibly measure a solid cam valve lash in the blink of an eye.
Or you can adjust the solid valve lash in an OHC engine with shim adjustment with the engine running? That I would like to see.
Setting lash with 2 feeler gauges per setting, the 2nd .001 bigger gives us a "go,no-go" for those that can't get the feel correct, example .018 is the target, and add a .019 as the "no-go".
I'm ending this now.
Gary
