  #22 (permalink)
Old 07-26-2020, 06:55 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
In general, the torque of a normally aspirated engine is directly related to and limited by its displacement, so a 358 ci engine has a maximum potential torque of about 450-500 ft lbs, depending upon multiple factors including compression ratio, dry sump?, etc.
Horsepower is a measure of work, is a calculated number based upon the torque an engine generates and its corresponding rpm, such that mathematically the numbers are always the same at 5252 rpms.
You can do the calculations, so for a 358 ci engine to make 900 hp , it would have to run likely higher than 9000 rpm’s , generating near maximum torque at that rpm.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
