Thread: 0* Engine Angle
Old 07-27-2020, 08:19 AM
mthrockmorton mthrockmorton is offline
Do you have a handle on the rear axle angles at this point? May also be worth checking the angle (if any) that may be present at the mounting surface for the carb. (Some mfg compensate for engine angle here to level the carb. I consider 3 degrees a bit steep for u-joints...I strive to keep driveshaft angles at 1 to 2. 3 at the carb is ok ish...and should it become problematic, a tapered spacer under the carb is an option...
