Old 07-27-2020, 12:24 PM
patrickt patrickt is offline
Originally Posted by Whodeeny View Post
Patrickt -
I have a different fan than you have (SPAL VA18-AP70/LL-86A). Maybe I should try your fan instead. At Summit it goes for $151. I will give ERA a call to ask if it works. Thanks for the info on the fan you have.
BD
It should work -- ERA picked it out for me. If you're using their standard braces it will be a breeze to install. Here's a pic. One thing I did notice was that about 14 years ago the connectors that go to that fan, and that are right below the upper radiator hose on the driver side, were not making a good connection at the wiring harness and I was getting an intermittent voltage drop because of the resistance from the crappy connection. You might want to check that.
