Old 07-27-2020, 02:53 PM
patrickt patrickt is offline
Originally Posted by Kit Coyle View Post
Patrick...do you pull any or all of the spark plugs to make it easier to turn the engine over more easily?
I pull no plugs, the engine will turn very easily and you turn it as if you were tightening the bolt. That bolt is torqued to around 90 to 100 ft/lbs so have no fear that you are over tightening it somehow. You aren't. The bolt that is in the end of your crank will either be a normal big bolt, or the newer ones actually have a 1/2" square hole in them that fit the the square on your ratchet wrench, or the end of a short extension, so you don't even use a socket. This is wayyyyy easier than bumping it with a remote starter.
