Thread: A&C headers
Old 07-28-2020, 10:25 AM
cobrabritt83 cobrabritt83 is offline
Cobra Make, Engine: A&C 427 s/o
Default A&C headers
Finally got my engine back from the dyno shop and got it mounted into the frame along with the trans. I went to put my side pipes on and noticed the driver's side side pipe points straight to the ground. It takes a lot of force to get the side pipe to sit level. The passenger side went on straight and didn't require any force to sit level. not sure if this is a problem with the header or the engine placement. I did double check and the engine is sitting level and the passenger side header measured 22 1/2" like it should.
