Old 07-29-2020, 07:34 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Its difficult to tell from a picture-----but some retainers and keeper combos such as that are for use with lash caps that will push on the keepers to transfer the movement against the valve retainer instead of totally just against the valve tip. This removes the force needed to open valve against these extremely high valve spring pressures from the keeper /valve stem grove in these modern small stem valves.
