Old 07-29-2020, 10:06 AM
6TNCRZY 6TNCRZY is offline
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
The valves and pushrods are not at the same angle but close, the difference is about 20 degrees. If the geometry was correct before, the pushrods would need to be a little less than .070" longer. Check your pattern on the valve tip, probably will be OK as is.
