Old 07-30-2020, 01:44 PM
1795's Avatar
1795 1795 is offline
Originally Posted by CSX 4133 View Post
Jim,
I doubt it was the braking, unless you already noted it pulling hard or lockup under braking previously. Is your car equipped with a brake bias adjustment? Like you summarized, not rev matching more than likely caused the hard clutch engagement and rear end to lose traction. Do you heal and toe routinely under braking/downshifts? Or are you simply blipping the throttle on downshifts where braking isn't needed?
~Steven
Steven,
I heal and toe routinely on downshifts. I think that I either forgot or did not blip it enough. Also, as I stated in a prior post, was probably going to fast to downshift into 2nd at 88 mph probably could not have blipped the rpms that much to speed match. Should have trail braked into the corner more and then downshifted. Thanks.
Jim
