Old 08-02-2020, 12:24 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
I think Evan's coolant is basically propylene glycol (prestone low tox), similar to ethylene glycol, which both have a boiling point of about 385 degrees. Therefore, it really never turns into the gaseous phase , and never develops high pressures, like water based coolants. Also, because of no water, there is much reduced corrosion. However, glycols have about 50% the rate of heat transfer, and heat capacity, and because of this, the engine needs to run at a higher temperature to transfer / remove the same amount of heat.
Maybe not the best for a high performance engine ? Maybe better for a regular classic car, driver ? Water based coolant is more effective for removing engine heat.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
